That wouldn’t fix the issue if I have the same dashboard name in 2 instances, would it
Anyway, seems my proposal makes more sense than to have to duplicate “overview”.
Bottom-line is that we have an instance name, so why not using that rather than the hardcoded “Home Assistant”? If you want to keep “Home Assistant”, it’d just be easy to set your instance name to that.
Heh? I was assuming that “Why not create another dashboard, call it something else as “Overview” and set it as default” is because you absolutely love the “Home Assistant” part, otherwise I don’t see the point of you remark as an inplicit -1…
Seriously, I really don’t care about your feature request. I simply offered a solution to your ‘issue’ which is availble right now and can be done within 10 seconds. I even suggested to vote for your own request. If you consider this a -1, I think you got up on the wrong side of the bed.
Maybe just not a common understanding of what a Feature Request is?
I can think of a half-dozen workarounds, and if I didn’t, I would have posted some request for assistance.
Honestly, it’s not important enough for me, either, that I spend time creating hacks.
It just seems worthwhile to suggest an quick-win improvement to get the functionality out-of-the-box.
