Use HA to send Whatsapp messages to group
I want to have Home Assistant send notifications as part of an automation to phone numbers (mine or my partner’s) or groups in Whatsapp. I’ve seen a few integrations available, but I’m not sure which are trustworthy. I figure the official one can’t be easily connected to HA?
How can I implement such a whatsapp-notification service and which integrations are trustworthy?
These are the ones I’ve come across:
I use callmebot. not had any issues so far quick and easy to setup.
2nd year here using CallMeBot. No issues with it all and has been very reliably and responsive. Would recommend.
Use callmebot since over 3 years, never Had any Problems with it.
@Frosty @santiniuk @Spegeli The only issue I have is that it can’t send something to a whatsapp group. Do you use something else for that?
not sure if this is of use to you.
https://github.com/t0mer/matterbridge-custom-notifier
not used it myself just stumbled across it after searching for a solution for you
Thanks! I’ve come across that one (it’s linked in the OP) but not a lot of people used it and there’s not much info about it, so I was hesitant due to security / privacy concerns with that one and the WAPI. CallMeBot is used more often, and is spoken about more often
For those who use CallMeBot, how do you send messages to groups?
Still no answer ?
Its Paid service for message groups (have to use textmebot or twilio), as you can notice from their webiste. suggest using greenapi (GitHub - t0mer/green-api-custom-notifier: Send whatsapp notification using green API) works fine with groups.
I created a pull request which adds the ability to send WhatsApp messages to groups: GitHub - raulpetruta/ha-wa-bridge: A custom integration to send and receive WhatsApp messages in Home Assistant naturally. It uses a local whatsapp-web.js bridge running in Docker.
You can wait for it to be approved, or just use my forked repo instead since it requires adding a custom repo in HACS and in Apps (formerly Add ons) anyway.
Tnx. I don’t see the qr code
