Use HAOS laptop's built-in mic & speakers
Hello!
I have HAOS on a laptop. Voice Assist is set up locally & everything works so far, i.e., I can speak commands via android phone app when at home.
HAOS currently doesn’t see its own internal mic & speakers as a device/entity that I can target announcements/conversations to. Is it even possible to use the built-in mic and speakers of my HAOS laptop for Voice Assist?
Has anyone had any luck with this? Can anyone help with this, please?
If the devices are defined in the system, you can run the necessary modules to handle sound. But this solution has many limitations.
It is better to make a satellite from esp32+INMP441+MAX98357A
