Use Home Assistant & Aqara Magic Cube for Romance <3
Tags: #<Tag:0x00007f3265468630> #<Tag:0x00007f3265468108>
Hope I got your attention :slight_smile:
Let’s use Home Assistant not only to automate our homes, but also our love lives!
I need your help!
The idea is that it takes 36 questions to fall in love with someone (it’s science :stuck_out_tongue: and It’s in the paper!)
Reading them from a list is boring; so I want to use the Aqara Magic Cube for it. Only by flipping from side to side there are 36 triggers: 1 -> 2, 1 ->3 etc.
A simple example is:
Video
This is the code for it:
- id: '1601567476657'
  alias: '| Cube 1 naar 2'
  description: ''
  - platform: event
    event_data:
      event: 2001
    event_type: deconz_event
  condition: []
  - service: tts.cloud_say
      entity_id: media_player.kantoor
      message: What is the greatest accomplishment of your life?
      options:
        gender: female
      language: en-US
  mode: single
But this requires 36 automations with a question per automation.
Is there a way to randomise this without asking a question twice?
Or is it possible to create 1 base automation that uses a list to get it’s questions?
Another idea I have is to break it into different levels of questions. So that for example when you drop the cube or tap it twice it cycles to a different list of questions and to make this visible a nearby light turns from yellow to blue.
I’m still a HA novice so I would think about an automation that switches of a list of automations and turns on others, but I’ve got a feeling this can be done much more effective and lean.
I’m curious about your ideas and suggestions!
Cheers, Ruben
I use input selects to hold data . Input selects are just lists
This could hold all your messages , then you could call them via the cube results
Interesting! thanks i’ll look into it!
