I am trying to combine the electrical price combined with weather forecast to automate my heat pump. Lets say I have a four hour window, I can set the indoor temperature down a couple of degrees for the most expensive our, and then reset to normal when the price is better.
This could easily be done with only price, but if I want to check of it is going to be colder, then I want to run now even if it’s expensive.
I can see the hourly forecast in the weather integration, but I don’t know how to use it in automation.
For example, my base outdoor temp is 15 degrees C, and if it is colder, i use the delta t and divide the price with the delta
