Hi there.
I am relatively new to homeassistant. I am currently moving my entire setup from FHEM to homeassistant and I am already quite satisfied. Only with the integration of my RGBWW-LED-controllers I have a problem. There is no „ready-to-sie“ integration because they are “diy controllers”. They can be controlled either via HTTP-REST or via mqtt. MQTT works so far, but unfortunately I need a custom JSON schema and can only set the color via hsv-model and the template schema doesn’t offer this option. Is there a specific reason for the limitation? Currently I use the sliders for white-value and color-temp to set hue and saturation, but a real colorpicker is much more comfortable.
Another option would be to convert rgbw to hsv, but for this I still lack too much scripting knowhow in ha
This is my current config:
- platform: mqtt
schema: template
effect_list:
- blink
- pause
- stop
- continue
- skip
state_topic: "rgbww/rgb_stripe2/color"
brightness_template: "{{ (value_json['hsv']['v'] / 100 * 255) | int }}"
color_temp_template: "{{ (value_json['hsv']['s'] | int) + 1 }}"
white_value_template: "{{ (value_json['hsv']['h'] / 360 * 255) | int}}"
command_topic: "rgbww/rgb_stripe2/cmd"
command_on_template: >
{"jsonrpc":"2.0","method":"color","params":{"hsv":{
{%- if color_temp is defined -%}
"s":{{ color_temp - 1 }},
{%- else -%}
"s":"+0",
{%- endif -%}
{%- if white_value is defined -%}
"h": {{ white_value / 255 * 360 }}
{%- else -%}
"h":"+0"
{%- endif -%}
{%- if brightness is defined -%}
,"v":{{ (brightness / 255 * 100) | int }}
{%- else -%}
,"v": 100
{%- endif -%}
},"d":"1","q":"single"
{%- if transition is defined -%}
,"t":{{ transition * 1000 }}
{%- else -%}
,"t":1000
{%- endif -%}
,"cmd":"fade"}}
command_off_template: >
{"jsonrpc":"2.0","method":"color","params":{"hsv":{"h":"+0","s":"+0","v":0},"d":"1","q":"single"
{%- else -%}
,"t":1000
{%- endif -%}
,"cmd":"fade"}}
min_mireds: 1
max_mireds: 101
state_template: >
{%- if value_json['hsv']['v'] == 0 -%}
off
{%- else -%}
on
{%- endif -%}
