I want to be able to trigger this A/C switch by tapping the icon in a banner-card. This does work for my lights (group.kantoor) with light.toggle which is defined as a ‘service’, but not for the A/C as a custom switch. What am I doing wrong here?
Unfortunately it still doesn’t work, as soon as I add tap_action and I add to spaces for ‘action’, the icon disappears Using the code below as you suggested doesn’t seem to work:
ok sorry. im not sure how the “toggle action” will react on your template_sensor, maybe you need a toggle_service there … if such exists
PS: cording to the “Banner-Card” docs, it seems like you can put the Icon in the “map_state” position, thou that seems for changing icon, but maybe that would apply also to show the specific Icon
Tried to move the “value: mdi:air-conditioner” there, below both cool and heat ( or different icons for different “map_state” ) … thou i don’t know if you can define both " color: " and " Icon " under map_state
…Or maybe you should actually define the icon in your “switch” template … im not very “experienced” with template-sensors
I also tried to move the icon around but that doesn’t seem to do much. I’ll try to read more documentation see if I can find a way to fix this.
The other weird thing is, when I click the text-label ‘Airco’, I am able to use that switch you see below:
But after I switch it on, the switch itself automatically moves back to ‘off-state’. So if I want to turn the Airco off, using that switch again, I first have to switch it to ‘On’ and then again to ‘Off’, so the switch doesn’t stay in the correct position. If this makes any sense…
Ordinary “Switch”, with a “tap_action”, and then hide the “on/off toggle” , so somehow you have defined a “toggle switch”, i don’t know if that’s in the Template, or the banner-card the define “Action” as a toggle … i was thinking about suggesting another Card, but it seemed like you already put alot of effort in making this card look Cool
I really don’t know how the ‘toggle’ part is defined, because the configuration.yaml only contains the switch statement and there’s also no toggle action defined with the card itself.
Using a different card is not really a solution I’m willing to go for, except if that card provides the same options as the banner-card.
Update
I fixed the fact that the switch falls back into the previous state by removing this line from the Configuration.yaml file: value_template: "{{ is_state_attr('climate.air_conditioning_air_care', 'sensor_state', 'on') }}"
I know…I realized this a couple of minutes ago which made me change that line. Unfortunately did didn’t help. My last update, removing the value_template, prevents the switch from falling back in it’s original state. So that’s fixed for now, changing the pop-up in:
Where those icons stay in the state ‘on’ or ‘off’.
The only issue left for now is that I want to operate that switch by tapping the icon, instead of the text label with a pop-up first.
I know, but I have a tablet in the livingroom, showing 5 banner cards:
Living room
Office
Bedroom
Bathroom
Car
Those banner-cards give a quick overview of what’s going on, like living-room:
or the car:
I can tap on the light-bulbs to turn the lights on or off, I want to do the same for the airco. As soon as I tap the title of one of the banner cards, it opens a new ‘tab’ within HA and shows me all the devices in that room, so:
Climate cards
Light cards
Shutter cards
Heaters
etc…
That’s the way I’ve set it up for now because that makes it easy to control with a tablet.
you “define” 2 states here, cool/heat , but your template is service: climate.turn_on/off (which one will it be ?, turn_on Heat or turn_on Cool)
If your template_sensor actually turns your air-conditioner on/of, then you just need a CSS-“template” on the entity (i.e card-mod) , “if state_on: green” , and if your template_sensor actually should switch between Heat vs Cool , then “if state_heat: darkred” , but i have no idea how your template should look like, if you want to switch “State” between Heat/Cool
