Use input (fields) in script as sequences
How can I use a field (input to a script), such as
test_script:
  fields:
    sequences:
      description: Actions
      default: []
      selector:
- service: script.turn_om
    entity_id: script.test_script
    variables:
      sequences:
         - service: [...]
in an sequence in the script?
E.g you can do this with automation blueprints, e.g
- choose:
  default: <-- run it here
But I’m not able to do it in a script. Any ideas how I can accomplish that?
Not quite like that. You could put the service itself (the part you indicated with the ellipsis) in a variable and use it as a template, e.g.:
- service: "{{ the_service }}"
where the_service is e.g. light.turn_on.
Put more technically: If you’re used to the typical eval function many languages have, you can’t do that here.
https://www.home-assistant.io/integrations/script/#passing-variables-to-scripts
Congrats on the worst comment of the year! :tada:
Ah, its too bad. I like how you can call any sequence from inputs in blueprints.
<-- automations.yaml -->
use_blueprint:
  path: bp.yaml
  input:
    actions:
      - wait_for_trigger:
      - service: system_log.write
<-- bp.yaml -->
- choose:
  default: !input actions
If anyone knows how this can be accomplished from one script (passing it as variables) that script.turn_on another script, I would appreciate to hear from you.
Everything you asked about is available at the link I posted. You just have to put a little effort in to read and understand it. I’m not spoon feeding you. Especially after that comment.
Good luck.
It’s not. It shows how to pass variables (title and message) and use them in a notification of the called script, not to call them like described here - and that’s what my question is about.
You put your actions in a script and call that, passing any variables you need to.
Tips
  • If you want to alienate others, that’s how to do it. However, it’s self-defeating because it’s a disincentive for others to help you.
  • There are tens of thousands of users in this community forum. However, only a surprisingly small number of them regularly volunteer their time to help others … and you just made a needlessly snarky reply to someone who helps a lot of people.
  • FAQ Guideline 22
Hello, found this thread as I was trying to do a similar thing.
After searching around on GitHub and testing it out myself, it seems you can’t execute an action passed into a script as a field (a runtime variable). You can, however, execute an action set when the script is configured.
For example, see the “confirm” and “dismiss” actions in this blueprint: core/confirmable_notification.yaml at b6d001bfe6f00db0461861c0894d5bc83306b038 · home-assistant/core · GitHub
The downside to this, obviously, is once the script is configured to do A and B, it will only ever do A and B, rather than allowing the user to tell it to do C on this specific run.
(To make it run the sequence of action(s) you’ve set, you can use a conditional. You can bypass the conditional by setting it to “true”: HAConfig/medication_reminder.yaml at 4feba7a7650adb23dbd36622911cab7d9e5a798d · MTrab/HAConfig · GitHub)
