Use integer array on lambda
Im trying to use an integer array on lambda actions. some thing like:
globals:
  - id: hours_on
    type: int[3]
    restore_value: no
    initial_value: '{9,9,10}'
  - id: minutes_on
    type: int[3]
    restore_value: no
    initial_value: '{0,30,0}'
the action:
    then:
      - lambda: |-
          int i=0;
          for( i=0; i==2; i++)
            ESP_LOGD("main", "Time on: %i:%i",id(hours_on)[i].state ,id(minutes_on)[i].state);
probably is something really easy but I have not enought expirence…
Without actually trying it myself - have you tried: id(hours_on).state[i]
yes, it does not work.
Also try:
- lambda: |-
          int j=0;
          int hr;
          int minute;
          for( j=0; j==2; j++)
            hr = id(hours_on)[j];
            minnute =id(minutes_on)[j];
            ESP_LOGD("main", "Time on: %i : %i ", hr, minute);
It does not work either.
It seems like the for conditional does not work. I can’t get ESP_LOGD to print on the screan while inside the for loop.
I feel a little embarrassed…
This works!
for( j=0; j<=2; j++)
- lambda: |-
          int j=0;
          int hr;
          int minute;
