I have been experimenting with controlling my media_player volume through a KNX switch. The approach I used was to use a dimming object in KNX. The volume adjustment catches the on/off switch events in Home Assistant, using automation to adjust the volume in steps. The long-press in KNX generates the dimming action in KNX, which I catch and use to trigger play/ pause automations.
Relevant parts from configuration.yaml
knx:
tunneling:
fire_event: true
fire_event_filter: ["3/5/*"]
automation:
- alias: "Increase Volumer"
platform: event
event_type: knx_event
event_data:
address: '3/5/0'
data: 1
condition:
condition: template
value_template: "{{ (float(states('sensor.volume_achterkamer')) <= 0.9) }}"
- service: media_player.volume_set
data_template:
entity_id: media_player.achterkamer
volume_level: '{{ (float(states("sensor.volume_achterkamer")) + 0.1) | round(2) }}'
- alias: "Decrease Volume"
platform: event
event_data:
address: '3/5/0'
data: 0
condition:
condition: template
value_template: "{{ (float(states('sensor.volume_achterkamer')) > 0.1) }}"
data_template:
volume_level: '{{ (float(states("sensor.volume_achterkamer")) - 0.1) | round(2) }}'
- alias: "Media Play"
platform: event
event_data:
address: '3/5/2'
data: 9
service: media_player.media_play
- alias: "Media Pause"
platform: event
event_data:
address: '3/5/2'
data: 1
service: media_player.media_pause
The result is that you need multiple presses of a button to lower the volume in discrete steps (in this case 10% of volume, but you can off-course take bigger or smaller steps), and can use the long-press for media play/pause. This works fine. In the ideal case however, I would like to have a long press continually lower/ increase the volume until the button is released. Short press can then be used for play/ pause. Is there anybody who got that working, or has any ideas for alternative approaches?
