Hi everyone,
I have some code that starts to get a bit long and I was wondering if there is a way to use lambda templates to define the switch to manipulate in an automation.
Let me explain, currently I have the following code:
- platform: gpio
pin:
number: 17
mode: INPUT_PULLUP
on_press:
then:
lambda: |-
auto valve = id(valve_select).state;
if(valve == "valve1"){
id(valve_1_switch).toggle();
else if(valve == "valve2"){
id(valve_2_switch).toggle();
where “valve_select” is a select component with options: “valve1” and “valve2”
As I am planning to add more valves I was trying to do:
- platform: gpio
pin:
number: 17
mode: INPUT_PULLUP
on_press:
then:
- switch.toggle: !lambda return id(valve_select).state;
But I get the error:
This option is not templatable!
My question is: Is there a way to accomplish what I am trying to do? Perhaps not with lambdas, but in another way? Or with lambdas but in a different fashion?
Thanks for your help!
