is it possible to use mdi icons provided by ha in css passed to a card by card_mod?!
at the moment i’m downloading the svg to be used…
thanks
thanks
What do you need it for?
I can name cases like “change an icon for a feature in a Tile card”.
i’m changing the icon of an entity in a glance card using card_mod and :hover… i can’t find infos about mdi icons path to use
Post a short code for a glance card with, let’s say, colored icon on hover for a start.
i’m using this line in my css…
mask: url( '/local/images/mdi/wifi-remove.svg' ) !important;
i need to know if i can use mdi icons without needing to download and put them in /local folder first…
This is not what I asked. Anyway, try using “––card-mod-icon” variable fir a hovered element.
already tried, --card-mod-icon doesn’t work with :hover
to verify, simple code attached to a glance entity
card_mod:
style: |
state-badge:hover {
background: red !important;
--card-mod-icon: mdi:wifi-remove;
:host:hover not recognized…
What about the background, is it styled?
Means - make sure that the selector works ok.
yes, background works… but this not the problem… i’m using this (working) code now
card_mod:
style:
state-badge $ ha-state-icon $ ha-icon $: |
ha-svg-icon:hover {
mask: url( '/local/images/mdi/icontouse.svg' ) !important;
mask-position: center center !important;
mask-repeat: no-repeat !important;
i need, if possible, to use icons without needing to download them… in other words, how do i avoid to use /local/images/mdi/icon.svg in favour of mdi:icon?!
