I’m using the whois platform to get the expiration dates of my domains
- platform: whois
domain: domain1.com
- platform: whois
domain: domain2.com
For each domain, I have an automation to send a notification when there are fewer than 31 days to expiry.
- alias: domain1_sensor_notify
platform: time
at: "10:00"
condition:
condition: numeric_state
entity_id: sensor.domain1
below: 31
service: notify.email
data_template:
title: "domain1.com expiring"
message: "Remaining days {{states.sensor.domain1_sensor.state}}"
- alias: domain2_sensor_notify
platform: time
at: "10:00"
condition:
entity_id: sensor.domain2
below: 31
data_template:
title: "domain2.com expiring"
I’d like to have a single automation that works for all whois sensors. I’m new to writing automations, so could anyone suggest how to do this?
I believe you can add entity_id
entity_id:
- sensor.domain1
- sensor.domain2
You could just trigger off the state of either sensor going below 31:
- alias: domain_sensor_notify
platform: numeric_state
entity_id:
- sensor.domain1
- sensor.domain2
below: 31
data_template:
title: "domain expiring"
message: "{{ trigger.to_state.friendly_name )): remaining days {{trigger.to_state.state}}"
Without checking the details I think that should work.
123
(Taras)
May 26, 2020, 2:32pm
4
This:
trigger.to_state.attributes.friendly_name
or this:
trigger.to_state.name
tom_l
May 26, 2020, 2:53pm
5
Though if you wish to retain the 10am trigger for the message, create a group containing all your domain sensors. Lets call it group.my_domains
platform: time
at: "10:00"
condition:
condition: template
value_template: >
{{ states|selectattr('entity_id','in',state_attr('group.my_domains','entity_id'))|selectattr('state','lessthan', 31 )|list|count|int > 0 }}
data_template:
title: "The following domains are expiring"
message: >
{{ states|selectattr('entity_id','in',state_attr('group.my_domains','name'))|selectattr('state','lessthan', 31 )|list|join(', ') }}
Though this does not give the number of days left for each sensor. I’m still thinking about how to do that.
Thanks I’ll give this a go.
When I try to trigger it manually through the web interface, I see the error
Undefined Error: 'trigger' is undefined
I’m not sure if that’s because there’s a problem with my config, or if I just have to wait until it triggers for real.
petro
(Petro)
May 26, 2020, 3:00pm
7
I’d go the dynamic messaging route, but it would be a longer message:
- alias: Message Me About Domains
- platform: time
at: "10:00"
condition:
- condition: template
value_template: >
{%- set ns = namespace(cnt=0) %}
{%- for s in states.sensor | selectattr('attributes.expires', 'defined') %}
{%- if s.state | int < 31 %}
{%- set ns.cnt = ns.cnt + 1 %}
{%- endif %}
{%- endfor %}
{{ ns.cnt > 0 }}
- service: notify.email
data_template:
title: Expiring Domains
message: >
The following domains are set to expire:
{%- for entity in states.sensor | selectattr('attributes.expires', 'defined') %}
{%- if entity.state | int < 31 %}
{{ entity.name }} will expire in {{ entity.state }} days.
{%- endif %}
{%- endfor %}
EDIT: I had to fix a ton of typos, long morning. If it doesn’t work out of the box, take a screenshot of the entities and I can fix the generator.
Thanks for the suggestion. The value_template
is a bit more complicated to understand as a home-assistant beginner, but keeping the 10am trigger makes it easier to test by temporarily setting it 2 minutes in the future.
tom_l
May 26, 2020, 3:05pm
9
Petro’s solution actually lists the expiring domains as well as the number of days left. Mine just lists the expiring domains. Go with his solution.
Edit: hey @petro in your template, should this:
be:
selectattr('attributes.expiration_date', 'defined')
Edit 2: never mind. Had a look at the source and your attribute is correct. The documentation is misleading.
petro
(Petro)
May 26, 2020, 3:19pm
10
Yeah, I went straight to the code because there’s no ‘good’ resource for possible attributes.
Thanks for the suggestion. It gives the error:
TypeError: '<' not supported between instances of 'str' and 'int'
How can we convert to an int before the < 31 comparison?
petro
(Petro)
May 26, 2020, 3:24pm
12
oof, forgot about that. Hmm. It’s going to be a harder template for the condition
{%- endif %}
{%- endfor %}
{{ ns.cnt > 0 }}
EDIT: I edited the previous comment for a full solution.
EDIT EDIT: Gotta change the other template too… hold up.
That’s working now. Thanks everybody for your help and suggestions.
