Does anyone know if there is a way to use the NC Cloud to get access to the configuration and automation files in HA, for example using SSH?
TIA
I donāt think so. They donāt yet support services running on different ports through Remote UI (like most of the Hass.io addons or services like SSH) and I hope thatāll change. Even if you integrate the addons into the UI via iframe, itās still just a window to service running on another port.
OK cheers rccoleman. I live in hope.
Ask and ye shall receive, apparently
I am not running hassio but home assistant core (new nomenclature) in a docker. And I am a Nabu Casa customer. I am not on a statci IP.
I want to access my docker host via SSH from the outside of my network. Can I use the Nabu Casa url and connect via portforwarding and ssh keys my rasparry pi behind the firewall (port forwarding enusred).
Or do I need another dyndns service to get the IP adress?
Regards
Ralf
