There are situations where we may want a different automation trigger duration at based on other criteria, It would be helpful to be able to used a number helper value as the trigger duration.
Options
Duration: None, Static Value, Helper
(If static then the current HH:MM:SS box would show up)
Helper Entity: All numeric helpers
Units: Hours, Minutes, Seconds
Thank you, that worked. With the recent UI updates to automations, I’m starting to migrate some of my automations from node-red into native HA automations. The advice to not use device is great and I’ll be sure to avoid it. Fortunately, I have only migrated 7 of them so far, so updating them won’t be a big deal.
Back to my original request, while I’m not opposed to writing yaml/templates, it would still be nice to do it all in the UI.
