Hi!
I’ve started adding some Broadlink components to HA. I’ve added sensors, alarm kit and some power switches. So far so good. However I notice that I can’t differentiate between the eAir sensors in HA. I’ve tried using friendly_name like I did for the switches but I get an error message that says it’s not supported. I find it strange since it works fine on the switches.
Invalid config for [sensor.broadlink]: [friendly_name] is an invalid option for [sensor.broadlink]. Check: sensor.broadlink->friendly_name. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.broadlink/
Has anyone found a way to use friendly_name or some other method to get specific names on the sensors?
My code for configuration.yaml is below. You find the sensors after the switch section.
switch:
- platform: broadlink
host: 192.1681.xx
mac: 'B4:43:0D:C5:xx:xx'
friendly_name: 'Lys vindu 1.etg'
type: sp3
host: 192.168.1.xx
mac: 'B4:43:0D:F0:xx:xx'
friendly_name: 'Lys kontor'
type: sp3
host: 192.168.1.91
mac: '34:EA:34:B6:xx:xx'
friendly_name: 'Hage Lys'
type: sp3
scan_interval: 60
host: 192.168.1.xx
mac: 'B4:43:0D:70:xx:xx'
friendly_name: 'Bar'
monitored_conditions:
- temperature
- humidity
- air_quality
- light
- noise
- platform: broadlink_s1c
ip_address: 192.168.1.xx
mac: '34:EA:34:59:xx:xx'
timeout: 10
