Hey guys, let me explain:
I have a gpio switch that turns my radiator on and off
switches.yaml:
- platform: rpi_gpio
ports:
8: radiator_upstairs
I also have a template switch that uses two scripts to turn the gpio switch on and off according to a timer set by an input_number:
switches.yaml:
switches:
#radiator auto off
radiator_upstairs_auto:
value_template: "{{ is_state('switch.radiator_upstairs' , 'on') }}"
turn_on:
service: script.turn_on
entity_id: script.radiator_upstairs_auto_on
turn_off:
entity_id: script.radiator_upstairs_auto_off
and scripts,yaml:
######## Radiator - upstairs
######## TIMED ON AND OFF
radiator_upstairs_auto_on:
sequence:
- service: switch.turn_on
entity_id: switch.radiator_upstairs
- delay: '00:{{ states.input_number.radiator_timer_upstairs.state | int }}:00'
# seconds: 3600
- service: switch.turn_off
######## SIMPLE OFF
radiator_upstairs_auto_off:
sequence:
- service: script.turn_off
So far, so good.
The problem starts when i try to implement a generic Thermostat as an alternative to the timer.
I want to have both options available.
- platform: generic_thermostat
heater: switch.radiator_upstairs
target_sensor: sensor.dht_sensor_temperature
min_temp: 15
max_temp: 22
target_temp: 15
cold_tolerance: 0.3
hot_tolerance: 0.5
min_cycle_duration:
seconds: 10
The thermostat works well when enabled.
On the other hand, as soon as i enable the code for the thermostat, it will screw up my timed template switch.
What happens is, i put the thermostat to a lower target temperature than the current, say my current is 18 and i set it at 15.
When i turn on the “manual” timed switch, the switch turns on, but is forced closed in ~30 seconds, leaving the radiator_upstairs_auto_on
script running (i cant re-enable the template switch).
I came to the conclusion that the problem is the generic thermostat because i have disabled the last part of the code and the timer works as intended.
Any ideas?
