mcnahum
1
I would like to the have switch to use the HUE API to activate/ deactivate my HUE sensor.
This is workinging outside Home assistant correctly
I added the below lines on my configuration.yaml
#Hue sensor action
switch hue:
The switch is there, off, if I activate is comeback off directly and doing nothing… any idea?
Tediore
2
I actually use a command line switch for this for a very specific use case.
switch:
- platform: command_line
switches:
laundry_room_motion_sensor:
command_on: curl -X PUT -d '{"on":true}' "http://10.0.1.40/api/API_KEY/sensors/55/config"
command_off: curl -X PUT -d '{"on":false}' "http://10.0.1.40/api/API_KEY/sensors/55/config"
command_state: curl "http://10.0.1.40/api/API_KEY/sensors/55/"
value_template: "{{ value_json.config.on }}"
friendly_name: Laundry room motion sensor status
Adapt to your info of course.
mcnahum
3
that make sense …
I saw it’s not working here … which log will you check to understand the issue?
Tediore
4
The home assistant log at configuration > logs
