I would like to create a blueprint that allows the user to enter RGB colors for a lighting automation. I would then like to use these input parameters in the automation. Unfortunately, this does not work.
I have created the RGB color selector:
rgb_color_1:
description: The start-color of the sunrise simulation
default: [112,21,0]
selector:
color_rgb:
And declared these as input variables:
variables:
rgb_color_1: !input rgb_color_1
Now I want to call the variables in the code:
sequence:
- service: light.turn_on
entity_id: '{{light_entity}}'
rgb_color: '{{rgb_color_1}}'
I am still relatively new to .yaml, so I would be very grateful for simple solutions!
âThis does not workâ doesnât help us or you. How does it not work? Error messages in traces? Error messages in the logs? Type of light and integration? And post the complete code.
Oh, sorry!
With âUnfortunately, that doesnât work.â I meant the following:
If I execute the code as I have written it above, the selected light simply remains off. However, no error messages are displayed.
If I manually enter values for the rgb_color variable in the sequence, the automation works.
The complete code:
blueprint:
name: Wake-up light alarm with color sunrise effect
description: 'A wake-up light alarm with a brightness and color temperature sunrise
effect. Note: Requires date_time_iso sensor in configuration, not manually executable!'
domain: automation
input:
light_entity:
name: Wake-up light entity
description: The light to control. Turning it off during the sunrise will keep
it off. Color temperature range is auto-detected.
selector:
entity:
domain:
- light
multiple: false
timestamp_sensor:
name: Alarm timestamp sensor
description: 'Sensor with timestamp of next alarm with device_class: timestamp
(set to ''none'' for manual alarm time)'
default: none
selector:
entity:
device_class:
- timestamp
multiple: false
manual_time:
name: Manual alarm time
description: Time to trigger alarm every day if timestamp sensor is not set.
Settings at or shortly after midnight will not work as expected!
default: '7:00:00'
selector:
time: {}
check_entity:
name: Additional entity to check before sunrise is triggered
description: If set, checks if entity is 'on' or 'home' before triggering. Use
e.g. a (workday) sensor, device_tracker or person entity.
default: none
selector:
entity:
multiple: false
sunrise_duration:
description: The sunrise will start the configured number of minutes before
the timestamp.
default: 25
selector:
number:
min: 1.0
max: 60.0
step: 1.0
unit_of_measurement: min
mode: slider
start_brightness:
name: Minimum brightness
description: The brightness to start with. Some lights ignore very low values
and may turn on with full brightness instead!
default: 1
selector:
number:
min: 1.0
max: 255.0
step: 1.0
mode: slider
end_brightness:
name: Maximum brightness
description: The brightness will be transitioned from the minimum to the configured
value.
default: 178
selector:
number:
min: 1.0
max: 255.0
step: 1.0
mode: slider
rgb_color_1:
default: [112,21,0]
selector:
color_rgb:
rgb_color_2:
description: The second color of the sunrise simulation
default: [160,71,31]
selector:
color_rgb:
rgb_color_3:
description: The third color of the sunrise simulation
default: [207,120,62]
selector:
color_rgb:
rgb_color_4:
description: The end color of the sunrise simulation
default: [255,171,97]
selector:
color_rgb:
pre_sunrise_actions:
description: Optional actions to run before sunrise starts.
default: []
selector:
action: {}
post_sunrise_actions:
description: Optional actions to run after sunrise ends (around the alarm time).
default: []
selector:
action: {}
source_url: https://gist.github.com/sbyx/96c43b13b90ae1c35b872313ba1d2d2d
variables:
light_entity: !input light_entity
sensor: !input timestamp_sensor
sunrise_duration: !input sunrise_duration
start_brightness: !input start_brightness
end_brightness: !input end_brightness
range_brightness: '{{float(end_brightness)-float(start_brightness)}}'
manual_time: !input manual_time
seconds: '{{float(sunrise_duration) * 60}}'
tick_time: '{{float(seconds) / float(range_brightness)}}'
check_entity: !input check_entity
rgb_color_2: !input rgb_color_2
rgb_color_3: !input rgb_color_3
rgb_color_4: !input rgb_color_4
- platform: time_pattern
minutes: '*'
condition: []
- wait_template: '{{sensor == ''none'' or as_timestamp(states(sensor), None) != None}}'
- wait_template: '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
~ '' '' ~ manual_time) - as_timestamp(states(''sensor.date_time_iso'')) <= float(seconds)
and states(check_entity) in [''unknown'', ''on'', ''home'']}}'
- choose: []
default: !input pre_sunrise_actions
- condition: template
value_template: '{{sensor == ''none'' or as_timestamp(states(sensor), None) != None}}'
value_template: '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
~ '' '' ~ manual_time) - as_timestamp(now()) <= float(seconds) and states(check_entity)
- choose:
- conditions:
- '{{state_attr(light_entity, ''min_mireds'') != None}}'
sequence:
brightness: '{{start_brightness}}'
entity_id: !input light_entity
default:
- repeat:
while:
- '{{sensor == ''none'' or as_timestamp(states(sensor), None) != None}}'
- '{{0 < as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
~ '' '' ~ manual_time) - as_timestamp(now()) <= float(seconds)}}'
sequence:
- delay: '{{tick_time}}'
- choose:
- conditions:
- '{{0 < state_attr(light_entity, ''brightness'') | int(0) < end_brightness
| int}}'
sequence:
- choose:
- conditions:
sequence:
brightness: '{{(float(end_brightness) - (float(range_brightness) *
(as_timestamp(states(sensor) if sensor != ''none'' else states(''sensor.date'')
~ '' '' ~ manual_time) - as_timestamp(now())) / float(seconds)))
| int(0)}}'
transition: '{{seconds / 2}}'
- delay:
seconds: '{{seconds / 2}}'
rgb_color: '{{rgb_color_2}}'
| int(0)}}'
- delay:
rgb_color: '{{rgb_color_3}}'
| int(0)}}'
- delay:
rgb_color: '{{rgb_color_4}}'
| int(0)}}'
default:
brightness: '{{(float(end_brightness) - (float(range_brightness) * (as_timestamp(states(sensor)
if sensor != ''none'' else states(''sensor.date'') ~ '' '' ~ manual_time)
- as_timestamp(now())) / float(seconds))) | int(0)}}'
- choose: []
default: !input post_sunrise_actions
mode: single
max_exceeded: silent
Thereâs a lot of code in your brightness
template. Does it produce a value guaranteed to be at least 1
? If the light is off and you only try to set a color without also specifying brightness
or brightness_pct
, or you specify it as 0
, nothing will happen.
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
January 22, 2025, 7:10am
6
alexthegreat:
'{{rgb_color_1}}'
Maybe itâs text that looks like a list, try casting it as a list.
`'{{rgb_color_1 | list}}'`
Also I have this if it helps you at allâŚ
Color-Multi-Tool
Thank you very much! The trick was to format the variable as a list. Now the automation works as it should.
