Use RGB light to show energy usage
Created an automation to look at solar production and house consumption and use this to create a smooth gradient going from green to purple:
[0, 255, 0], # Green
[255, 255, 0], # Yellow
[255, 165, 0], # Orange
[255, 0, 0], # Red
[128, 0, 128] # Purple
I’ll post the yaml from the automation below, feel free to adapt or turn into a blueprint:
alias: moodlight-smooth
description: ""
  - platform: state
    entity_id:
      - sensor.solar_power
  - platform: state
    entity_id:
      - sensor.house_consumption
condition:
  - condition: device
    type: is_on
    device_id: b047855b83e3f24f3705a659b20f496f
    entity_id: light.calex_moodlight_5_8w_rgb_cct
    domain: light
  - service: light.turn_on
      rgb_color: >
        {% set colors = [
          [0, 255, 0],
          [255, 255, 0],
          [255, 165, 0],
          [255, 0, 0],
          [128, 0, 128]
        ] %} {% set min_val = -3000 %} {% set max_val = 2500 %} {% set house =
        states("sensor.house_consumption") | float %} {% set solar =
        states("sensor.solar_power") | float %} {% set value = house - solar %}
        {% set normalized = (value - min_val) / (max_val - min_val) %} {% set
        num_colors = colors | length %} {% set segment = (num_colors - 1) *
        normalized %} {% set index = segment | int %} {% set weight = segment -
        index %}
        {% if index < num_colors - 1 %}
          {% set r = (colors[index][0] * (1 - weight) + colors[index + 1][0] * weight) | int %}
          {% set g = (colors[index][1] * (1 - weight) + colors[index + 1][1] * weight) | int %}
          {% set b = (colors[index][2] * (1 - weight) + colors[index + 1][2] * weight) | int %}
        {% else %}
          {% set r, g, b = colors[-1] %}
        {% endif %}
        [{{ r }}, {{ g }}, {{ b }}]
mode: single
Make adaptions to the jinja template to use your own sensors and lower and upper limits. Play around with the template in your dev tools to get it right for your own setup:
{% set colors = [ [0, 255, 0], [255, 255, 0], [255, 165, 0], [255, 0, 0], [128, 0, 128]      ] %}
{% set min_val = -3000 %} **#changethis to max solar**
{% set max_val = 2500 %}  **#changethis to value from where you want to see purple**
{% set house =  states("sensor.house_consumption") | float %} **#change this to your actual sensor**
{% set solar =  states("sensor.solar_power") | float %} {% set value = house - solar %} **#change this to your actual sensor**
{% set  num_colors = colors | length %}
{% set segment = (num_colors - 1) *  normalized %} {% set index = segment | int %}
{% set weight = segment -  index %}
{% else %}
{% endif %}
Thank for you for sharing, works great.
I tried turning it into a blueprint with selectable color gradient
Not fully working yet as I am yet to find a way to use the selected enitities in the data template section of the automation. Any suggestions from blueprint masters more than welcome
got the blueprint working now. Also posted it on blueprint exchange in case anyone finds it usefull…
Question: what are the values from grid and solar? mine are in kW. it looks like the code is in W? am i correct? so how can i adjust this? or do is set like -6 and 8?
example my solar:
Looks like it, yes.
(I deleted my other reply. I read it backwards.)
Yep indeed. All my sensors are in W.
Changeg the blueprint (take control) and divide everything by 1000 or template your sensors to do *1000 to convert them to W
Thank you, I will change this.
