Use Scenes in KNX and Homeassistant
Hi there,
I have no realy solution for my problem.
I have a Scene GA (0/2/0) on my KNX Bus and want to trigger this one, if I activate a Scene in HASS.
Also in the other Direction. If I activate a Scene with one of my KNX Actors, I want to get this to Hass, and trigger some Devices, who I have configure in the scene Section of Hass.
I have no really good solution for that.
If I add the scenes in my knx.yaml, than I can not configure these in the Scene Config UI of Hass.
Yeah, the scenes from HA aren’t 100% compatible to the ones from knx.
Use a knx_event to listen to the GA and scene numbers to trigger your HA scene from an automation.
But then I have to create for each scene a automation? If I have 50 Scenes, I need 50 Automations only to listen for Scenes on the KNX Bus? Is there not a simple Solution?
You can create one automation listening for all these scenes if you prefer 🤷
Do you have maybe an example? I am new in Hass. This would be great. :heart_eyes:
No, I don’t. Just try to do a state trigger on a scene number sensor and choose an associated action between the different scene numbers.
Thank you for that.
Here is my solution for everyone :slight_smile:
alias: "Event: Szene vom KNX Bus"
description: ""
  - platform: event
    event_type: knx_event
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ trigger.event.data.value == 1 }}"
        sequence:
          - service: scene.turn_on
              entity_id: scene.fernsehen
            metadata: {}
      - conditions:
            value_template: "{{ trigger.event.data.value == 2 }}"
        sequence:
              entity_id: scene.entspannen
            metadata: {}
      - conditions:
            value_template: "{{ trigger.event.data.value == 3 }}"
        sequence:
              entity_id: scene.nacht
            metadata: {}
      - conditions:
            value_template: "{{ trigger.event.data.value == 4 }}"
        sequence:
              entity_id: scene.zentral_aus
            metadata: {}
      - conditions:
            value_template: "{{ trigger.event.data.value == 5 }}"
        sequence:
              entity_id: scene.weihnachten_ein
            metadata: {}
      - conditions:
            value_template: "{{ trigger.event.data.value == 6 }}"
        sequence:
              entity_id: scene.weihnachten_aus
            metadata: {}
    default:
      - service: notify.notify
          title: Automation für Szene brachte Fehler
          message: >-
            Die Szene mit der Nummer {{ trigger.event.data.value }} konnte nicht
            in Home Assistant gefunden werden. Bitte Automation ergänzen
mode: restart
I have also added a default condition, to notify me, if there is no Scene in Hass, that I have added in my ETS.
:+1: looks great!
Thx for this good overview. I tried to set this up on my end. But does this work in a regular automation or do I need to set this up in my config yaml or do I need to add it at least add the KNX address x/x/x to the configuration YAML?
Thx! I am just getting started.
Hi :wave:!
knx_event needs setup in configuration.yaml. Have a look at device trigger actions for a way that doesn’t need that
Hi guys,
Thanks for this interesting discussion. I tried to do the same: fire a HA automation triggered bij a KNX wall switch… and I finally succeeded.
Might be helpfull to others to note that the telegram for invoking KNX scene nr 1 has 0 as payload, scene nr 2 has 1, etc…at least with my MDT binäreingang. Took me half a day to realize that.
On the other hand, I don’t see the GA numbers appear in the ‘destination’ input field in the automation, as shown in the video.
I had put this in my configuration.yaml (1/0/15 is the GA of the scene)
knx:
  event:
    - address:
        - "1/0/15"
      type: "scene_number"
  light:
    - name: "Living staanlampen"
      address: "1/0/3"
      state_address: "1/0/5"
      brightness_address: "1/0/12"
etc.....
Any idea?
Head to the Knx panel and upload your project file to get that.
Scene numbers are always payload + 1. So it will have payload: 0 and value: 1
The config you did in yaml is for knx_event - this is actually something different from the device trigger. You can just type a GA in the device triggers text field - even if you don’t have values in the dropdown.
