Hi together. this is my first topic here as i was just a power reader here.
I have 1 question.
i bought a zigbee motion detection from Silvercrest, which works very fine if you use it for … a normal motion detection.
But i want to use it in the bathroom, as someone enters the bathrom, the lights turns on.
then the light should turn off, when the person, leaves the room.
Currently i tried it as follows:
- Light on, when motion detected
- Delay for 80 seconds (the detector from Silvercrest has an timeout for about 70 seconds after detection)
- if no detection, turn off the light.
Then i set the mode of the automation to RESTART.
Means, if there is a detection, it should start at step 1 again with 80 seconds delay again or not?
anyway it works not as smooth as i did hope.
Does anyone else use it similar like me?
