Use Sonoff T1 3 Gang or 2 Gang for RGBW LED Strip
I have Sonoff T1s (1gang, 2gang & 3gang) with tasmota firmware all over my apartment and now I want to use LED Strip (for lighting) in some parts of my apartment. I know that for turning on/off I could still use Sonoff T1s but I was wondering if I could use the same switches for color control of LED strip as well?
I see the commands in tasmota github but I am not sure if this function is available through Sonoff T1s or through MagicHome?
I would appreciate if someone could give me a hand on the right direction
The T1’s are ony relays so cant do the PWM required for the different colours and brightness etc so you will need to use a MagicHome.
You could use a T1 as a dummy switch where you can set the MagicHome to predetermined colours etc depending on which switch is pressed and if you are doing a long key press or double press etc.
Thanks for clarifying this for me.
My next question is if I could use this:
Sonoff T1 (for switching on/off) -> MagicHome (LED coloring and stuff) -> LED Strip.
Also in HA would I be able to incorporate T1 switch with Magichome as one unit?
Example:
