Hi guys, I’m new to the forum, I was really hoping someone could help me with a condition in an automation… I’ve created an input_number slider to adjust a temperature setpoint. Now I’m trying to use that entity state (which is a temperature I wish to compare) in an automation. But under numeric_state, I can only input the value above or below I wish to trigger an action. I would really like to be able to use the slider value to be the condition below which value the automation should run
Do you mean you have another entity that represents the current temperature (in my example below I call it sensor.cur_temp
), and you want to trigger an automation if that entity goes below your input_number entity? If so, then you can use a template trigger. Something like this:
automation:
- alias: Temp drops below threshold
platform: template
value_template: >
{{ states('sensor.cur_temp')|float < states('input_number.low_threshold')|float }}
actions:
You can find more info here:
Hi, thank you for the reply. I managed to fix it a while back. Solution was very similar to your suggestion:
- id: '1529959612041'
alias: Nursery Min Temperature
value_template: '{{ (states.sensor.nursery_temperature.state | float) <= ((states.input_number.target_nursery_temp.state
| float) - 0.1) }}'
- data:
entity_id: switch.nursery_heater_switch
service: switch.turn_on
