I’m working on a new Blueprint that has a service call to turn on a light.
I’m trying to use a template to determine some attributes of this service call as per the documentation here:
Use templates to determine the attributes
Templates can also be used for the data that you pass to the service call.
You can use a template returning a native dictionary as well, which is useful if the attributes to be set depend on the situation.
service: climate.set_temperature
data: >
{% if states('sensor.temperature_living') < 19 %}
{"hvac_mode": "heat", "temperature": 19 }
{% else %}
{"hvac_mode": "auto" }
{% endif %}
My code is as follows:
- service: light.turn_on
data: >
{% if include_color_or_temp == "include_color" %}
"transition": "!input transition_time",
"rgb_color": "!input light_color"
{% elif include_color_or_temp == "include_temperature" %}
{ "transition": "transition_time_float", "temperature": "!input light_temp" }
{% endif %}
target: !input target_light
This gives the following error: expected float for dictionary value @ data[‘transition’]
transition_time is a number selector. I’ve already tried to change the code as follows:
variables:
transition_time: !input transition_time
transition_time_float: '{{ transition_time | float }}'
and then added it to the template as follows:
but the same error pops up.
If I remove the quotes around the transition_time_float variable or the !input transition_time variable , I get the following error: Error rendering data template: Result is not a Dictionary
I’m a bit at a loss here. Any help is greatly appreciated.
