pomah
(roman)
March 11, 2023, 8:50pm
1
Hi, I have a small issue with my latest automation, I want to make the code abit better and easier to follow so I want to use the “trigger_id” as part of the names and messages I send, se code below:
alias: INFO Pusa Mini+
description: ""
- platform: state
entity_id:
- sensor.prusalink_f9ccccf4b97be7799c1e605b96942571_printer_state
to: idle
for:
hours: 0
minutes: 0
seconds: 10
- platform: numeric_state
entity_id: sensor.progress
for:
hours: 0
minutes: 0
seconds: 5
above: 9.5
below: 11
for:
hours: 0
minutes: 0
seconds: 5
above: 89.5
below: 91
condition: []
- if:
- condition: trigger
then:
- service: camera.snapshot
filename: /config/www/cctv/{{ trigger.id }}.jpg
entity_id: camera.my_camera
- service: notify.mobile_app_
message: {{ trigger.id }}% done
title: Prusa Mini+
image: www.mydns.com/local/cctv/{{ trigger.id}}.jpg
- if:
then:
title: Prusa Mini+
- if:
then:
message: Print done!
title: Prusa Mini+
mode: single
But I cant figure out who to syntax it correctly, any ideas?
Since the action sequences for both the “10” and “90” triggers are essentially the same, with the templating filling in the desired information, you can collapse those two into a single stanza.
Using a Choose Action
description: ""
- platform: state
entity_id:
to: idle
for:
hours: 0
minutes: 0
seconds: 10
for:
hours: 0
minutes: 0
seconds: 5
above: 9.5
below: 11
for:
hours: 0
minutes: 0
seconds: 5
above: 89.5
below: 91
condition: []
- choose:
- conditions:
sequence:
title: Prusa Mini+
default:
filename: "/config/www/cctv/{{ trigger.id }}.jpg"
message: "{{ trigger.id }}% done"
title: Prusa Mini+
image: "www.mydns.com/local/cctv/{{ trigger.id}}.jpg"
mode: single
Equivalent action section, but using If/Then Action
- if:
then:
title: Prusa Mini+
else:
title: Prusa Mini+
mode: single
pomah
(roman)
March 20, 2023, 4:50pm
4
Hi I figured the same after reading your first post and the final result looks like this:
alias: INFO Prusa Mini+ v2
description: ""
- platform: state
entity_id:
to: idle
for:
hours: 0
minutes: 0
seconds: 5
for:
hours: 0
minutes: 0
seconds: 5
above: 9.5
below: 11
for:
hours: 0
minutes: 0
seconds: 5
above: 19.5
below: 21
for:
hours: 0
minutes: 0
seconds: 5
above: 29.5
below: 31
for:
hours: 0
minutes: 0
seconds: 5
above: 39.5
below: 41
for:
hours: 0
minutes: 0
seconds: 5
above: 49.5
below: 51
for:
hours: 0
minutes: 0
seconds: 5
above: 59.5
below: 61
for:
hours: 0
minutes: 0
seconds: 5
above: 69.5
below: 71
for:
hours: 0
minutes: 0
seconds: 5
above: 79.5
below: 81
for:
hours: 0
minutes: 0
seconds: 5
above: 89.5
below: 91
condition: []
filename: " /config/www/cctv/prusa.jpg"
entity_id: camera.prusa_cam
data: /local/cctv/prusa.jpg
title: Prusa Mini+
message: "{{ trigger.id }}"
mode: single
Another option:
- platform: state
entity_id:
to: idle
for: "00:00:05"
variables:
message: "Done"
value_template: >
{% set x = states('sensor.progress') | float(0) %}
{{ (1 >= (x % 10) or (x % 10) >= 9.5) and ( 90 > x > 9 ) }}
for: "00:00:05"
variables:
percentile: "{{ states('sensor.progress') | round(-1) | int }}"
message: "{{ percentile }}% done"
condition: []
title: Prusa Mini+
message: "{{ message }}"
mode: single
