UPDATE
Tronity have released a custom integration in HAC’s
This works without issue. Please use instead
I have been unable to use the Stellantis API to extract information from my Vauxlhall Corsa-E. The third party PSA Car Controller addin seems to be missing data, and for me has been unreliable. I stumbled on the third party Tronity app. This is a paid service but provides a wealth of information and an API I can use. The phone app is also much better than the PSA one
I have created a Node-Red flow to extract the data from the Tronity api. This is based on the the following Tronity - get SOC for your BEV from their API (flow) - Node-RED
The flow will create the following sensors. It will require the Node-RED Companion Integration
Lastupdate
GPS Tracker
Odometer
Charge Status
Range
Millege
Cable
The flow has some documentation built in . You will need a Tronity account linked to your car and login to the API.
This code will extend your free trial to 4 weeks and give me a month free.
Updated with better instructions v3 and scubbed code
Updated 22/10/2022 as Tronity have changed the api
Added Charge Power and Charge remaining time entities
Updated 18/11/2022 Changed last update state to mins rather than hours fix Bugs Tidy code ( copy shamelessly !) thanks @ pmuk
[{"id":"c19de7dca674fbd1","type":"tab","label":"Tronity","disabled":false,"info":""},{"id":"2c1cd936024c090d","type":"http request","z":"c19de7dca674fbd1","name":"Get data","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":400,"y":340,"wires":[["3897d42d56402287","1f8a3b2be030ad33","6e9694a727dbfa3e","1644367a5f5e9edc","02425b84808d8ccb","e6b440297bc2cc6e","7ba6d8b089095cf4","3237bc1ea39a6d6c","d8cb2e9516708391","822ed5b88887df70"]]},{"id":"45dbece70049d1d0","type":"http request","z":"c19de7dca674fbd1","name":"Post Auth","method":"POST","ret":"obj","paytoqs":"query","url":"https://api.tronity.tech/authentication","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":280,"y":220,"wires":[["96b9a28cae2d0186"]]},{"id":"fa68aef5ff9cef58","type":"inject","z":"c19de7dca674fbd1","name":"15 minutes","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"900","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":160,"wires":[["a3f5d9024fe73b88"]]},{"id":"769bc94a09907e76","type":"comment","z":"c19de7dca674fbd1","name":"Get car info ","info":"","x":90,"y":280,"wires":[]},{"id":"e3197fcf1ed9b18c","type":"comment","z":"c19de7dca674fbd1","name":"Get new token every 15 minutes ","info":"","x":200,"y":60,"wires":[]},{"id":"96b9a28cae2d0186","type":"change","z":"c19de7dca674fbd1","name":"Store Token","rules":[{"t":"set","p":"tronitybearer","pt":"flow","to":"payload.access_token","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":220,"wires":[[]]},{"id":"41112a71d20a7d04","type":"function","z":"c19de7dca674fbd1","name":"Build API","func":"let token = flow.get('tronitybearer')\nlet car = flow.get('car')\nlet measure = flow.get('measurement')\nmsg.headers = {\n 'Authorization': 'Bearer ' + token,\n 'Unit-System': measure,\n}\nmsg.url = \"https://api.tronity.tech/tronity/vehicles/\" + car + \"/last_record\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":260,"y":340,"wires":[["2c1cd936024c090d"]]},{"id":"2eed05c0b7a1c63e","type":"inject","z":"c19de7dca674fbd1","name":"3 minutes","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"180","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":340,"wires":[["41112a71d20a7d04"]]},{"id":"1c88e0ca45cf9de3","type":"comment","z":"c19de7dca674fbd1","name":"Info (click me)","info":"1) Login here: https://app.platform.tronity.io/\n(same credentials as in the app)\n\n2) Open the existing app. Needed are 4 things:\n- ID \n- Password (regenerate a new one to show it)\n- Number of your car\n- Measurement imperial or metric\n\n3) Enter ID,password,car number, imperial or metric into setup Tronity params \n\n4) change the Home Assistant names of all the blue sensors to match your car details , change unit of measure mi/km \n5) GPS data function names the device tracker \"corsae\" change to match your car details \n","x":90,"y":40,"wires":[]},{"id":"3897d42d56402287","type":"function","z":"c19de7dca674fbd1","name":"GPS data","func":"msg.payload = {\n data: {dev_id: \"corsa\",gps: [msg.payload.latitude,msg.payload.longitude],gps_accuracy: \"100\"}}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":860,"wires":[["0ea5d1851edb62a2"]]},{"id":"0ea5d1851edb62a2","type":"api-call-service","z":"c19de7dca674fbd1","name":"Create tracker","server":"","version":5,"debugenabled":false,"domain":"device_tracker","service":"see","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":800,"y":860,"wires":[[]]},{"id":"3200da140b1c5468","type":"function","z":"c19de7dca674fbd1","name":"Login Payload","func":"let client = flow.get('client')\nlet password = flow.get('password')\n\nmsg.payload = {'client_id': client,\n 'client_secret': password,\n \"grant_type\":\"app\"\n}\n \n\n\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":460,"y":160,"wires":[["45dbece70049d1d0"]]},{"id":"a3f5d9024fe73b88","type":"change","z":"c19de7dca674fbd1","name":"Tronity params ","rules":[{"t":"set","p":"client","pt":"flow","to":"","tot":"str"},{"t":"set","p":"password","pt":"flow","to":"","tot":"str"},{"t":"set","p":"car","pt":"flow","to":"","tot":"str"},{"t":"set","p":"measurement","pt":"flow","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":160,"wires":[["3200da140b1c5468"]]},{"id":"1f8a3b2be030ad33","type":"ha-sensor","z":"c19de7dca674fbd1","name":"All data","entityConfig":"176d488f557e35c4","version":0,"state":"payload.odometer","stateType":"msg","attributes":[{"property":"range","value":"payload.range","valueType":"msg"},{"property":"SOC","value":"payload.level","valueType":"msg"},{"property":"Charge Status","value":"payload.charging","valueType":"msg"},{"property":"Plugged In","value":"payload.plugged","valueType":"msg"},{"property":"Latitude","value":"payload.latitude","valueType":"msg"},{"property":"longitude","value":"payload.longitude","valueType":"msg"},{"property":"Last update","value":"payload.lastUpdate","valueType":"msg"}],"inputOverride":"allow","outputProperties":[],"x":620,"y":340,"wires":[[]]},{"id":"6e9694a727dbfa3e","type":"ha-sensor","z":"c19de7dca674fbd1","name":"Range","entityConfig":"05758513e60898cb","version":0,"state":"payload.range","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":610,"y":400,"wires":[[]]},{"id":"1644367a5f5e9edc","type":"ha-sensor","z":"c19de7dca674fbd1","name":"Mileage","entityConfig":"1c63d4adcc9c4770","version":0,"state":"payload.odometer","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":620,"y":580,"wires":[[]]},{"id":"02425b84808d8ccb","type":"ha-sensor","z":"c19de7dca674fbd1","name":"Charge Status ","entityConfig":"0e98215a55ad0ce0","version":0,"state":"payload.charging","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":640,"y":640,"wires":[[]]},{"id":"e6b440297bc2cc6e","type":"ha-sensor","z":"c19de7dca674fbd1","name":"SOC","entityConfig":"2c9fb2aa82cf4aef","version":0,"state":"payload.level","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":610,"y":460,"wires":[[]]},{"id":"7ba6d8b089095cf4","type":"ha-binary-sensor","z":"c19de7dca674fbd1","name":"Cable","entityConfig":"08ee2ea801be48bd","version":0,"state":"payload.plugged","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":610,"y":520,"wires":[[]]},{"id":"3237bc1ea39a6d6c","type":"ha-sensor","z":"c19de7dca674fbd1","name":"Charge Power","entityConfig":"5b61acc67627921e","version":0,"state":"payload.chargerPower","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":640,"y":700,"wires":[[]]},{"id":"d8cb2e9516708391","type":"ha-sensor","z":"c19de7dca674fbd1","name":"Charge Remaining Time","entityConfig":"8002120e974c1696","version":0,"state":"payload.chargeRemainingTime","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":670,"y":780,"wires":[[]]},{"id":"822ed5b88887df70","type":"function","z":"c19de7dca674fbd1","name":"mins","func":"msg.nomn = Math.round(Math.abs((Date.now() - msg.payload.lastUpdate) / 1000 / 60 ));\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":610,"y":920,"wires":[["441ddc047af385fd"]]},{"id":"f00e5f7a25c39ca4","type":"ha-sensor","z":"c19de7dca674fbd1","name":"lastupdate","entityConfig":"8ae07a618641546e","version":0,"state":"msg.nomn","stateType":"msg","attributes":[{"property":"time","value":"time","valueType":"msg"},{"property":"lastupdate","value":"payload.lastUpdate","valueType":"msg"},{"property":"date","value":"date","valueType":"msg"}],"inputOverride":"allow","outputProperties":[],"x":1010,"y":920,"wires":[[]]},{"id":"441ddc047af385fd","type":"moment","z":"c19de7dca674fbd1","name":"Date","topic":"","input":"payload.lastUpdate","inputType":"msg","inTz":"Europe/London","adjAmount":0,"adjType":"days","adjDir":"add","format":"DD/MM/YY","locale":"C","output":"date","outputType":"msg","outTz":"Europe/London","x":750,"y":920,"wires":[["dfe9a7afc8bb4b6e"]]},{"id":"dfe9a7afc8bb4b6e","type":"moment","z":"c19de7dca674fbd1","name":"Time","topic":"","input":"payload.lastUpdate","inputType":"msg","inTz":"Europe/London","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm:ss","locale":"C","output":"time","outputType":"msg","outTz":"Europe/London","x":870,"y":920,"wires":[["f00e5f7a25c39ca4"]]},{"id":"176d488f557e35c4","type":"ha-entity-config","server":"c7744623.68df68","deviceConfig":"","name":"sensor config for All data","version":6,"entityType":"sensor","haConfig":[{"property":"name","value":"corsa_tronity"},{"property":"device_class","value":""},{"property":"icon","value":"si:vauxhall"},{"property":"unit_of_measurement","value":"mi"},{"property":"state_class","value":""},{"property":"last_reset","value":""}],"resend":true},{"id":"05758513e60898cb","type":"ha-entity-config","server":"c7744623.68df68","deviceConfig":"","name":"sensor config for Range","version":6,"entityType":"sensor","haConfig":[{"property":"name","value":"corsae-range"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:gauge"},{"property":"unit_of_measurement","value":"mi"},{"property":"state_class","value":""},{"property":"last_reset","value":""}],"resend":true},{"id":"1c63d4adcc9c4770","type":"ha-entity-config","server":"c7744623.68df68","deviceConfig":"","name":"sensor config for Mileage","version":6,"entityType":"sensor","haConfig":[{"property":"name","value":"corsae-mileage"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:counter"},{"property":"unit_of_measurement","value":"mi"},{"property":"state_class","value":""},{"property":"last_reset","value":""}],"resend":true},{"id":"0e98215a55ad0ce0","type":"ha-entity-config","server":"c7744623.68df68","deviceConfig":"","name":"sensor config for Charge Status ","version":6,"entityType":"sensor","haConfig":[{"property":"name","value":"corsae-charge"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:cable-data"},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""},{"property":"last_reset","value":""}],"resend":true},{"id":"2c9fb2aa82cf4aef","type":"ha-entity-config","server":"c7744623.68df68","deviceConfig":"","name":"sensor config for SOC","version":6,"entityType":"sensor","haConfig":[{"property":"name","value":"corsae-soc"},{"property":"device_class","value":"battery"},{"property":"icon","value":"mdi:battery"},{"property":"unit_of_measurement","value":"%"},{"property":"state_class","value":""},{"property":"last_reset","value":""}],"resend":true},{"id":"08ee2ea801be48bd","type":"ha-entity-config","server":"c7744623.68df68","deviceConfig":"","name":"binary sensor config for Cable","version":6,"entityType":"binary_sensor","haConfig":[{"property":"name","value":"corsae-cable"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:cable-data"},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""},{"property":"last_reset","value":""}],"resend":true},{"id":"5b61acc67627921e","type":"ha-entity-config","server":"c7744623.68df68","deviceConfig":"","name":"sensor config for Charge Power","version":6,"entityType":"sensor","haConfig":[{"property":"name","value":"corsae-charge_power"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:cable-data"},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""},{"property":"last_reset","value":""}],"resend":true},{"id":"8002120e974c1696","type":"ha-entity-config","server":"c7744623.68df68","deviceConfig":"","name":"sensor config for Charge Remaining Time","version":6,"entityType":"sensor","haConfig":[{"property":"name","value":"corsae-charge_remain_time"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"time"},{"property":"state_class","value":""},{"property":"last_reset","value":""}],"resend":true},{"id":"8ae07a618641546e","type":"ha-entity-config","server":"c7744623.68df68","deviceConfig":"","name":"sensor config for Last Update","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"corsae-lastupdate"},{"property":"icon","value":"mdi:clock-outline"},{"property":"entity_category","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":"mins"},{"property":"state_class","value":""}],"resend":true,"debugEnabled":false}]
