Hello all
I have some Somfy Blinds and I would like to control them in Home Assistant (without any Somfy Cloud).
For this, I have a Somfy Izymo Transmitter and a 2-Relay switch and an ESP with ESPHome.
The Izymo Transmitter works by connecting the com cable with either the S1 cable for one direction or S2 cable for the other direction or no connection for no movement of the blinds. So I can use two relays to connect Com to S1 with one or Com to S2 with the other Relay and control this with the ESP.
I got that already working. So I can use Switch 1 to open the blinds and Switch 2 to close the blinds.
Now I would like to integrate this a bit better into Home Assistant as with just two switches. Is there a way to define a Cover based on two switches? With an up button (that switches on switch 1 for a certain amount of time) and a down botton (that switches on switch 2 for a certain amount of time) and a stop button that turns both switches off?
