Use variables in a flow
I have a flow where I turn on/off lights dependent on lux and movement, but I would like to control how brightness dependent on part of day (day, evening etc.) I have the part of day as a sensor (values “day”, “morning”, “evening” etc.), I would then like to map brightness 100 to “day” and 10 to “night” etc. I would like to use this flow on a lot of light entities, so I guess it should be a subflow. How/where do I declare the brightness settings individually?
you can set it in global context so it will be available in all flows of your node-red setup:
Thanks, I am still pretty new to Node-Red, but how do I then map part_of_day “day” to brightness “100”?
switch node allows you to chose different outcomes. if it is day, the message is routed to upper output, otherwise lower output. for example add a service call node at the end of upper output for light.turn_on with data {“brightness_pct”:100}
[{"id":"15532dec.3e8be2","type":"switch","z":"de9989cc.589d18","name":"switch","property":"part_of_the_day","propertyType":"global","rules":[{"t":"eq","v":"day","vt":"str"},{"t":"eq","v":"night","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":520,"wires":[["2ded71b1.2aecce"],["fb835133.51ad6"]]},{"id":"2ded71b1.2aecce","type":"api-call-service","z":"de9989cc.589d18","name":"100%","server":"e447d17a.16a64","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hallway","data":"{\"brightness_pct\":100}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":530,"y":500,"wires":[[]]},{"id":"fb835133.51ad6","type":"api-call-service","z":"de9989cc.589d18","name":"10%","server":"e447d17a.16a64","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hallway","data":"{\"brightness_pct\":100}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":530,"y":540,"wires":[[]]},{"id":"e447d17a.16a64","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true}]
Thanks for your reply, how do I handle it when each light that I would like to use the sub flow with gas different brightness settings? So for one light brightness night should be 20 and for another light 30?
here you can adjust the brightness in the service call node.
