Hi all. I have a Zen thermostat that I have not deployed yet because I cant seem to set the max
and min
set_point temperatures for cooling (they show up with sliders for heat).
Im trying to write an automation so i can use zha_toolkit
to write the values to the thermostats hidden attributes when the heat max or min set_points change. (Ill settle for using the set_points for heat for cool as well)
the automation triggers correctly when the sensor
has a change but I cant seem to read that value and use it in my action
Heres what I have in my automation right now.
alias: sync max temps
description: ""
triggers:
- trigger: state
entity_id:
- sensor.heat_max
- sensor.heat_min
conditions: []
actions:
- variables:
temp_c: "1900"
set_temp_c: {{ sensor.heat_max | float }}
- action: persistent_notification.create
metadata: {}
message: max changed {{ set_temp_c }} c
mode: single
