Use variables in display/draw shapes
Is it possible to use a variable to draw a shape in Esphome display component?
For example:
int volume;
volume = id(sensor.sonos_volume_int).state;
it.filled_rectangle(0,0,volume,4);
This does not work. It just displays nothing.
The idea is to draw a rectangle where the length depends on what the value is of the volume variable.
The variable declaration seems to work: I’m able to display the variable with it.printf. But is it possible to reference it in other functions?
You need to make the volume a sensor.
  - platform: homeassistant
    entity_id: sensor.sonos_volume_int
That should make it usable in the display
I already have volume as a sensor. I’ve been trying this for a couple of weeks now, I think I already tried something like this.
How would I reference to that sensor in the rectangle? Something like this?:
it.filledrectangle(0,0,id(volume).state,4)
Always include all relevant parts in your question!
But yes that should be what you need. Perhaps it needs to be converted to int also
it.filledrectangle(0,0,int(id(volume).state),4)
Sorry, sensor was not in the current config anymore (thought is was, but removed it as I was not using it anymore).
I will try this suggestion.
Yes, it works!
Lambda:
it.filled_rectangle(20, 36, id(sonos_volume_int).state, 4);
My sensor:
The entity in the sensor already has an integer as value, so converting with int was not needed.
Thanks for the help. This opens up a whole lot of possibilities!
