User authentication
hi guys, I’ve searched all over but couldn’t find the solution. Since I’ve upgraded nodered tot >1.0 I couldn’t login. I’ve done a clean install; I’ve disabled ssl on both HA and node-red.; but whilst login it seems it times out and give a loging failed msg. The hassio system log message is the most explicit: 18-11-14 06:00:12 INFO (MainThread) [hassio.auth] Auth request from a0d7b954_nodered for gijs 18-11-14 06:01:14 ERROR (MainThread) [hassio.homeassistant] Error on call http://172.30.32.1:8123/api/: 18-11-14 06:01:14 INFO (MainThread) [hassio.auth] Home Assistant not running, check cache 18-11-14 06:01:14 WARNING (MainThread) [hassio.auth] No cache hit for gijs
I’ve done a curl on the ip/api from the nodered docker instance; but nothing weird happens there. I’m on HA0.82 and supervisor 139… I’m of course trying to login with the HA credentials
hopefully somebody can point me to the right direction
Did you read this;
hi, thanks for taking the time to help!
Yeah I did. But somehow it looks like the addon/hassio is not aware that home asssistant is running and thus not getting any user data
What I did found weird that in docker for node-red I’m perfectly able to do a curl on the API.
May be I should check that in the supervisor docker instance as well…
i have exactly the same errors, in my log and the web interface just won’t start. its killing me… and help or pointers would be great as I’m running out of options
