User authentication
#1
hi guys, I’ve searched all over but couldn’t find the solution. Since I’ve upgraded nodered tot >1.0 I couldn’t login. I’ve done a clean install; I’ve disabled ssl on both HA and node-red.; but whilst login it seems it times out and give a loging failed msg. The hassio system log message is the most explicit: 18-11-14 06:00:12 INFO (MainThread) [hassio.auth] Auth request from a0d7b954_nodered for gijs 18-11-14 06:01:14 ERROR (MainThread) [hassio.homeassistant] Error on call http://172.30.32.1:8123/api/: 18-11-14 06:01:14 INFO (MainThread) [hassio.auth] Home Assistant not running, check cache 18-11-14 06:01:14 WARNING (MainThread) [hassio.auth] No cache hit for gijs
I’ve done a curl on the ip/api from the nodered docker instance; but nothing weird happens there. I’m on HA0.82 and supervisor 139… I’m of course trying to login with the HA credentials
hopefully somebody can point me to the right direction
#2
Did you read this;
#3
hi, thanks for taking the time to help!
Yeah I did. But somehow it looks like the addon/hassio is not aware that home asssistant is running and thus not getting any user data
What I did found weird that in docker for node-red I’m perfectly able to do a curl on the API.
May be I should check that in the supervisor docker instance as well…
