Hi everyone,
Hopefully there are some users with experience with the following devices.
What I’m mostly wondering is the following:
- Can be used as a Router? (actually tested, not falsely claimed by the manufacturer).
- Is the touch sensor working well and responsive. (for comparison, I have several Livolo switches without Zigbee which have awesome touch sensors)
- Actual minimum load (for non N line versions).
- (bonus) Power usage when off.
I’ll add my own reviews first on two devices I already have.
Moes - ZigBee Wall Touch Smart Light Switch With Neutral/No Neutral ,No Capacitor Smart Life/Tuya Works with Alexa,Google Hub Required|Switches| - AliExpress
Device: TS0011 - _TZ3000_hhiodade
Should be able to function with and without Null line.
- Doesn’t matter whether you install the null line, it stays a TS0011 which is an end device and not a router!
- Not working as responsive as I’d like. You really need to properly touch the sensor and it has some delay so you can’t just walk by and hit it assuming it will work as it does with the Livolo switches.
- Min load (without N line) is 5W, the switch simply won’t turn on with a lower load.
- They claim to be <0.5W
You also cannot hear this switch, the relais isn’t audible as it is with the Livolo versions. I get the impression that this switch is made to fade-in the light, however, as it isn’t a dimmer, I don’t really understand the function of this. Non-dimmer bulbs simply cannot fade-in.
Not really fond of this device. It works but I can’t recommend it because of the bad responsiveness.
Bseed - Bseed Smart Zigbee Switches 1/2/3gang 1way Wifi Touch Light Switch Wall Sensor Switches Tuya Control Smart Life Google Alexa - Switches - AliExpress
Device: TS0011 - _TZ3000_hafsqare
Version without Neural/Null line.
- It’s an end device. They also have a Null line version but from what I understand from their support it’s also just an end device.
- It’s not as responsive as the Livolo switches and has a small delay but it’s definitely working better than the Moes switch.
- Works on a lot lower load than the Moes version (tested with a 2.5W GU10 bulb and works great!)
- They claim to be <0.2W
My experience with this switch is a lot better than that of the Moes switch. It’s still not a Zigbee router (presumably even with N line) but the responsiveness is a lot better.
This switch also has an audible click (relais) when you switch, just as the Livolo switches.
Other switches I’m interested in:
WETEN: Updated review here: User experience request: Differernt Zigbee Tuya based touch light switches - #2 by jory - Bseed (With Neural/Null line!): BSEED 1/2/3Gang Zigbee Smart Wall Switch 1/2/3Way Touch Light Switches Alexa Google Home Tuya Wireless Control Need Neutral Wire| | - AliExpress > Their support says the Neural/Null line version is still not a router, through I’m not sure they fully understood my question. Maybe someone has this version and tell me more!
- GIRIER: GIRIER Tuya ZigBee Smart Switch, No Neutral Wire Required Touch Switch 95 250V, Works with Alexa Google Home No Capacitor Needed| | - AliExpress
- SMATRUL: Tuya Eu Zigbee Smart Touch Switch Light No Neutral Wire 1/2/3 Gang Wall On Off Magnetic Latching Relay For Alexa Google Home - Switches - AliExpress
- AVATTO: Avatto Tuya Zigbee Smart Light Switch,no Neutral,no Capacitor 1/2/3 Gang Touch Switch Smart Life Work With Alexa Google Home - Switches - AliExpress
- No brand?: ZigBee Wall Touch Smart Light Switch with Neutral/No Neutral,Smart Life/Tuya 1/2/3/4 Gang Control Compatible Alexa Google Home| | - AliExpress
Users who have experience with the non-touch light switches are also very welcome to comment! These devices do not have a small light which is always on so I can imagine these devices will work a bit different without Null line.
Thanks in advance!
