I just installed Python onto Windows and opened HA via CMD, however, I have on User or Password, is there a default? or am I missing something?
If new installation, you create them yourself.
When I log in through CMD it just asks for the user and password, never got the opportunity to create one.
You don’t login through CMD.
So Sorry I am so new to this.
I used this command C:…> py -m homeassistant --open-ui in CMD as per windows instalation instructions
Is there a link to how to log in to a windows installation ( Non-Paspberry Pi)
You don’t login through a terminal or app. You open a browser to the IP:port of the system.
I used the following as a guide. https://www.home-assistant.io/docs/installation/python/
and command lines in CMD.
When I put in 2nd line “hass --open-ui”
web page opened and displayed the following.
I never set a username or password.
Appreciate any assistance
That’s the first step that happens when you see the webpage though.
Windows is a very poorly supported (not officially supported actually) server to run home assistant on. I suggest you use Linux or Virtual box and run home assistant properly
OK thanks, I will do some searches on virtual box to see If I can get it working
