User name and password?
Did you use an SD card?
no, only because there is nothing to save or backup.
Then you have not read the docs carefully because using an SD card is not only when you want to restore a backup.
understood. i will purchase an sd card and see if i can follow the directions … fingers crossed
@Nick4 that worked! thanks so much
Hi, good you got it solved!
Please take the time to mark the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
