User theme ignored when selected? or is it a bug?
before I submit a bug, quick question
this may have been a change but I’m not sure. When themes are chosen, specifically backend-selected then automations changing that theme should only affect that particular ui. correct?
Running 99.3 and now when I choose a theme it only persists if the service was just started. Automations I have changing a theme (for backend-selected) are applying themes when the automation is triggered to ui in which the user selects their own theme. Did something change and I missed it? or is this a bug?
What? Please rephrase.
I have automations which change themes, at specified times.
Under the frontend the user can select a theme or choose backend-selected.
If backend-selected is chosen, automations change the theme.
If a specific theme is chosen, automations still change the theme.
The user chosen theme is not being applied.
It could be a bug if the behavior before worked that way. If you are making an assumption on the functionality, it may not go anywhere. I haven’t used that functionality, so I can’t really say much.
bug then. Off to submit a bug report. thanks
