I am having a hard time understanding how to mix jinja and yaml.
To reduce code duplication, I started what I thought was a simple script that could toggle poe on a number of ports on several network switches. I am using this button
type: button
entity: switch.poeswitch13_p10
name: POE switch 13 port 10
show_state: true
tap_action:
action: call-service
perform_action: script.poe_switchport_toggle
service_data:
id_switch: 13
port: 10
with this script
poe_switchport_toggle:
description: "Turn poe on or off on a specific switch and port"
fields:
id_switch:
description: "poe switch id"
example: "13"
port:
description: "poe switch port"
example: "10"
sequence:
- action: >
{% if states.switch.poeswitch{{ id_switch }}_p{{ port }}.state == "on" %}
switch.turn_off
{% else %}
switch.turn_on
{% endif %}
entity_id: switch.poeswitch{{ id_switch }}_p{{ port }}
which does not compile due to
which I have to replace with fixed values
{% if states.switch.poeswitch13_p10.state == "on" %}
to make it work for one specific port, which of course defeats the purpose. The final
works fine, though.
I know I could use
action: switch.toggle
but do not wish to do so as a. I want to understand parameters better and b. I am not sure if it covers an ‘undefined’ entity state.
Anyway - is it possible to construct entity names inside scripts?
Alternatively, could I use an ‘oldstate’ parameter that looks something like
service_data:
oldstate: {{ this.state }}
in the button card?
