I installed the battery-state-card from the HACS Frontend. When I tried to add it from the Add Card dialog I don’t see it. I tried to use the manual option and added custom:battery-state-card as the type. I got an error that it wasn’t found. Am I doing this wrong? Do I need to add something to the config?
In the repository for the frontend, the following example is given for a Card View:
type: custom:battery-state-card
title: "Battery levels"
entities:
- sensor.bathroom_motion_battery_level
- sensor.bedroom_balcony_battery_level
- entity: sensor.bedroom_motion_battery_level
name: "Bedroom motion sensor"
This is a link to the frontend repository
I found another post on the problem and it appears I’m doing what should be done. I tried to use two other custom cards. They are not being recognized either. When I enter custom: and then the card, it looks to be doing a search. All three have directories under www/community. Should there be something in the config file to point to them? I’ve seen mention of adding it as a resource in the Lovelace configuration panel. I tried it and it doesn’t work. I’m not sure of the format as I’ve seen two different examples. I tried:
/local/battery-state-card.js
