I have the following automation that monitors my water temperature. If it is low at 6:30AM geyser will be switched on for an hour.
I always get the notification that the geyser has been switched off irrespective of wether it was switched on or not. How can I modify the script so that I get the “OFF” notitification only if it was previously switched on?
alias: Geyser Control
description: ""
triggers:
- id: "on"
at: "06:30:00"
variables:
is_true: "{{ states('sensor.sonoff_1000beb2e9_temperature') | int(0) < 40 }}"
trigger: time
- id: "on"
type: temperature
device_id: f87c5830cbd79957b7d3686d81220335
entity_id: e742e7b6421924ce742fcb52d5c122b6
domain: sensor
below: 40
variables:
is_true: "{{ (6,30) <= (now().hour, now().minute) < (7,30) }}"
trigger: device
- id: "off"
at: "07:30:00"
variables:
is_true: "{{ true }}"
trigger: time
conditions:
- condition: template
value_template: "{{ is_true }}"
actions:
- metadata: {}
data: {}
entity_id: switch.sonoff_1000beb2e9
action: switch.turn_{{ trigger.id }}
- metadata: {}
title: >-
Geyser Control [{{ trigger.id }}]: {{
states('sensor.sonoff_1000beb2e9_temperature') }} °C
message: >-
Geyser control [{{ trigger.id }}]: {{
action: notify.mobile_app_nokia_x20
Thanks.
