Vaughanza
(Vaughan Lundin)
May 11, 2023, 7:25pm
1
Hi Guys,
I have automation ( google tts ) to announce when a door is left open.
Please can you help me how do I add a Helper into a CONDITION that I can toggle the automation on and off with the button card. remember my door shows open or closed and NOT on or off.
I create a Toggle Boolean but no success
Thanks in advance
Post your current automation so we don’t have to guess at its structure.
Vaughanza
(Vaughan Lundin)
May 11, 2023, 7:46pm
3
Thanks here is my code also it only announces once, would like to announce every 20 min:
`lias: Back Door open or Closed Announce
description: “”
platform: state
entity_id:
binary_sensor.back_door
to: “on”
for:
hours: 0
minutes: 0
seconds: 45
platform: state
entity_id:
to: “off”
condition: []
choose:
conditions:
condition: trigger
sequence:
service: tts.google_translate_say
cache: false
entity_id: media_player.home_group
message: Door is open
conditions:
condition: trigger
sequence:
cache: false
message: Door has been closed
mode: single`
rossk
May 12, 2023, 6:55am
4
So, you want a toggle to enable / disable the notification ?
If so then simply create an input Boolean helper then edit your automation and add a condition to include the state of the Boolean being on or off
Or have I misunderstood your requirements?
Vaughanza
(Vaughan Lundin)
May 12, 2023, 6:21pm
5
Thanks , could you help me. Do I add the input boolean helper ( toggle ) under condition and use STATE ?
If so do i add ON or OFF under state ?
rossk
May 12, 2023, 6:39pm
6
Yes, exactly that
Personal preference really. Depends how you want to think of the Boolean or what you call it…
Vaughanza
(Vaughan Lundin)
May 12, 2023, 6:40pm
7
Do I add the state as ON or OFF ?
rossk
May 12, 2023, 6:49pm
8
On or off, will depend on what you call your Boolean.
Boolean called ‘notifications on’ for example would require the condition, boolean state to be on for the automation to run.
Boolean called ‘notifications off’ would require the the condition, Boolean state to be off for the automation to run.
It’s all personally preference depending on what you name the Boolean, how you think of the Boolean etc
Vaughanza
(Vaughan Lundin)
May 12, 2023, 6:51pm
9
I want the toggle input boolean to turn off the automation via a button on dashboard or turn back on ?
Vaughanza
(Vaughan Lundin)
May 12, 2023, 6:55pm
10
I am using the Helpers ( Toggle ) in HA and was told to put under the conditions of my automation
luisgarcia87
(Daniel Garcia Elizondo)
May 12, 2023, 7:06pm
11
Hello, What exactly are you trying to achieve?
To create a button that would toggle the automation on or off you would need a button card on your dashboard like this:
Add card on your dashboard.
Select button card
show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: automation.name
Replace the entity with your desired automation name and the custom name that you want.
Again this would create a button that will turn on and off an automation, but I don’t think that’s your end goal here.
Vaughanza
(Vaughan Lundin)
May 12, 2023, 7:34pm
12
I have already created the Helper Toggle
I have already created a Custom button card that uses the Helper input Boolean toggle and it works.
I have an automation that tells me that the back door is open.
I was told to add the input boolean that I created and add to my automation ( under ) conditions so that I can stop the automation.
I don’t understand how to add it to my automation under conditions , this is my problem.
thanks
luisgarcia87
May 12, 2023, 7:50pm
13
Here’s an example automation that uses an input_boolean as a condition.
If the input_boolean.water_emergency is on the automation will not run. If it’s off the condition passes and the action is triggered. Is this what you looking for? You can also share your code so we can see the names for your entities and code it accordingly.
alias: Sprinklers On at 5:30 am
description: ""
- platform: time
at: "05:30:00"
condition:
- condition: state
entity_id: input_boolean.water_emergency
state: "off"
- type: turn_on
device_id: 71df7514ef30c6c17fe3fba2e669d8ff
entity_id: switch.water_pump
domain: switch
- type: turn_on
device_id: d7271b05c8d11b98eb14ba268c0a02a0
entity_id: switch.sprinklers_valve_switch_1
domain: switch
- delay:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
- type: turn_off
domain: switch
mode: single
Vaughanza
(Vaughan Lundin)
May 12, 2023, 7:58pm
14
This what i am looking for .
is that a toggle input boolean ?
If you toggle the input boolean to off will the automation stop and if on will the automation proceed ?
Trying to understand how that condition works ?
luisgarcia87
May 12, 2023, 8:04pm
15
That example automation triggers at 5:30 am and last for 5 minutes until the final action is completed
- type: turn_off
domain: switch
If I were to manually set the input_boolean to on at 5:29 am the automation would not run.
If I were to manually set the input_boolean to on at 5:32 am (after the trigger time) the automation would remain running because at 5:30 am (trigger time) the input_boolean was off at that time.
Does that answer your question?
Vaughanza
(Vaughan Lundin)
May 12, 2023, 8:07pm
16
Not really, I just want to stop the automation , its fine I found another way around it.
Thanks for helping appreciate it
Thanks to everyone for helping
