Been beating my head against this one for a couple hours. Now that we have a way to get alexa to do tts I’m trying to send basic weather underground information. I’m currently testing in the service development tool with the below.
{"entity_id": "media_player.echo_dot", "message": "The temp is {{ states.sensor.pws_temp_f.state }}"}
No matter what I try for the variable syntax it always reads the variable name instead of getting the value. Ideas?
Yes you’d need a data template to send that over in an automation so I guess it won’t work in the dev tools as this is not data template but a simple data…
here is mine I don’t use alexa as my media_player but i will be doing this very soon.
script:
james_briefing:
alias: James Briefing
sequence:
- service: tts.google_say
data_template:
entity_id: media_player.tts_kodi
message: >
{% if now().strftime("%H")|int < 12 %}
Good morning James.
{% elif now().strftime("%H")|int < 18 %}
Good afternoon James.
{% else %}
Good evening James.
{% endif %}
It's currently {{states.sensor.pws_temp_c.state|round}} degrees in Burleigh but feels like {{states.sensor.pws_feelslike_c.state|round}} degrees. Today will be {{states.sensor.pws_weather_1d_metric.state|replace(".", "")}}.
{% if now().strftime("%H")|int < 9 and now().strftime("%w")|int > 0and now().strftime("%w")|int < 6 %}
The current drive to Powertec in traffic is {{states.sensor.commute_to_work.state}}
{% endif %}
- service: media_player.alexa_tts
entity_id: media_player.bedroom_echo_dot
data_template:
message: >
Good morning, Thalles. The time is {{states('sensor.time')}}. It is currently {{states('sensor.dark_sky_apparent_temperature')}} degrees outside. Today's weather is {{states('sensor.dark_sky_summary')}}. There will be a high of {{states('sensor.dark_sky_daytime_high_temperature')}} and a low of {{states('sensor.dark_sky_overnight_low_temperature')}}. We can expect {{states('sensor.dark_sky_hourly_summary')}}
