Hey there,
i am using a blueprint to send me a picture of my entry if movement was detectet. The blueprint only accepts a motion sensor as trigger.
So, now i want to use a automation in front of the blueprint, wich indicates if f.e. the front door is open or closed. The notifiy should only be send if the front door is closed.
For that i want to create a virtual motion sensor. I want to use this sensor in a automation wich checks the status of the front door. If the door is closed, and the real motion sensor detects motion, the automation should set the state of the virtual motion sensor to “movement detectet”.
I already created the virtual motion sensor:
sensors:
helper_notify_eingang:
value_template: "on"
friendly_name: 'Helper Notify Eingang'
device_class: motion
But i am not sure if this is correct for what i want to do.
I can manipulate the state of the virtual sensor manually. But i cant manipulate the state out of a automation.
How can i do that?
Regards
Sebastian
