However, I get a validation error from the editor when I try to do this. What is the proper way to use this action selector output as the value of a sequence array? Thanks!
Same issue here. What exactly is the purpose of action selectors? Are they only used for blueprints?
Later edit, as I know this question will pop up: what is the use case?
I have an automation blueprint which takes in a climate component and a binary sensor (window sensor) and checks whether the window being open should trigger any automatic action. The action to be taken is defined at the automation level (as a blueprint input).
blueprint:
name: Take default action based on window openings
description: bla
domain: automation
input:
hvac:
name: HVAC thermostat
description: The climate component which controls the HVAC in the room/area
selector:
entity:
domain: climate
window_sensor:
description: The window or door sensor to be monitored
selector:
entity:
domain:
- binary_sensor
- input_boolean
turn_off_actions:
name: Turn down HVAC sequence
description: The action(s) to be taken if cooling/heating needs to be turned down/off in case of an open door/window
selector:
turn_on_actions:
name: Turn HVAC back up sequence
description: The action(s) that need to be taken once the disruptive condition is over (i.e. door/window is closed again)
selector:
mode: single
variables:
hvac: !input hvac
window_sensor: !input window_sensor
- platform: state
entity_id: !input window_sensor
to: "on"
- platform: state
to: "off"
condition:
- condition: state
entity_id: !input hvac
state:
- heat
- cool
- alias: "Act depending on window state"
choose:
- conditions:
- alias: "If window is open"
condition: state
state: "on"
sequence:
- service: script.notify_me_window
hvac: "{{hvac}}"
window_sensor: "{{window_sensor}}"
action_to_take: "{{turn_off_actions}}"
action_if_cancelled: "{{turn_on_actions}}"
- conditions:
- alias: "If window is closed"
condition: state
state: "off"
sequence:
hvac: "{{hvac}}"
action_to_take: "{{turn_on_actions}}"
action_if_cancelled: "{{turn_off_actions}}"
Then, since I want to 1. do the same thing in all rooms with a climate/window sensor combo and 2. share the blueprint, I’d like to have it call a script which does pretty much the same thing: take action and notify me about whether I want to revert the said action.
However, the script should have the notifications follow the same pattern, but the action(s) to be taken vary between rooms. As a consequence, I want to define the actions in the calling automation blueprint instance and use the actions as a part of what actions the script should do.
notify_me_window:
alias: Notify me about HVAC action
description: Notify that action was taken and offer the possibility to revert said action
fields:
action_to_take:
name: Action to take by default
description: This action will be taken by default when the notification is issued
selector:
default: []
name: Action if cancelled
description: This action will be taken if the user decides to undo the automatic modification via notification UI
selector:
default: []
variables:
initial_actions: >
{{ action_to_take + [{'service': 'notify.mobile_app_my_phone', 'data': {'actions': [{'action': 'CANCEL_HVAC_ACTION', 'title': 'Undo'}]}}] }}
sequence: "{{initial_actions}}"
mode: single
The clicking on “Cancel” part is not handled in the script, but that’s not really important at this stage. What’s more important is how to inject some user-defined actions in between some static actions of a script, be it for the entire script or as in @outdoorsgeek 's example, in a choose branch, for example.
If I’m reading that right, it sounds like you can’t use ANY action you want, you have to hard code all executable actions in the “runner” script and simply populate their parameters. Right?
