I have a rs485 connected keypad that I want to use for arming and disarming my alarm. I want to use the same “alarm_control_panel.code” to trigger an “action:”. I cannot seem to make it work.
My focus is on the action: → to: clause.
Ed
The following snip-it from my automations.yaml executes the intended action if I enter “1234” on my keypad.
- id: '1727041912854'
alias: Trigger Alarm 2a
description: ''
- platform: state
entity_id:
- sensor.rs485_pin
to: "1234"
- type: turn_on
device_id: fdf2f95d6479f1505e0cb8cf0d5322ff
entity_id: 3b9689c79345158c7e5f2032cf40d307
domain: switch
mode: single
If I change the to: clause to compare to the code setting in my alarm_control_panel does not execute the intended action.
-id: '1727041912854'
description: ''
- platform: state
entity_id:
- sensor.rs485_pin
to: alarm_control_panel.home_alarm_1700.code
- type: turn_on
domain: switch
mode: single
From my configuration.yaml my alarm_control_panel is as follows.
### Alarm Control Panel ####
alarm_control_panel:
- platform: manual
name: Home Alarm 1700
code: '1234'
code_arm_required: true
arming_time: 5 # The delay before arming.
delay_time: 3 # The pending state before alarm is triggered.
trigger_time: 120 # The time the alarm stays active.
disarm_after_trigger: false # Action after 120 seconds.
disarmed:
trigger_time: 0
armed_home:
arming_time: 0
delay_time: 0
