Using an AW-AB116H in a Micro PC with HAOS
I have recently installed HAOS onto a micro pc, its running well - it has an AW-AB116H card in it, the card is not seen by HAOS the card is apparently an Atheros AR9462 - is there anyway to utilise this card with HAOS for BT or is there another mini pci card i can use for Bluetooth?
I do have BT active with a USB Dongle
Welcome to the community.
You might find something useful here AzureWave AW-AB116H - TechInfoDepot
maybe but typically WiFi & BT cards are cheap so it should be an easy swap out. Personally I’d recommend ethernet though as it’s one less thing to worry about imo
Thanks. I should have been more informative, I already have Ethernet - actually on this particular box i have 4 (previously a PFSense box) , but i was more interested in getting the BT working rather than the Ethernet. But now i am wondering if i can get the Hailo-8 to fit and just use a USB BT module - Thanks for the link.
