I’m clearly being slow (and new to it)… but trying to build a Lovelace dropdown with all the climate entities, and a big ‘Boost’ button that will call a script based on the input_select value:
Thanks. It’s actually the climate.{{state.input_select.boost_input}} which is failing first, with 'Failed to call service script/climate_boost. Error rendering data template: UndefinedError: ‘state’ is undefined’.
Even if I fix the value other two data points, I get the same error…
That’s got it! Thank you so much - when you’re still flailing around, it’s really hard to know if you’ve got the totally wrong idea, or are missing various bits of obscure punctuation. Thanks again!
