Can I use a number from an input_text helper to set my on time in an automation?
Yes, but only if you use a template:
https://www.home-assistant.io/docs/automation/trigger/#state-trigger
Thanks, I didn’t think that I could edit automations.yaml when I use the UI to create them.
I don’t use the GUI automation editor but am pretty sure there is a “yaml view” mode you can use within the GUI.
Not for automations. Unless it’s well hidden.
Thanks- this tip goes into my notebook. (I knew it would be well hidden).
