Using Android Quick toggle timeout
I have added Homeassistant to Device Control Quick Toggle on Android to easily open the Garage Door, when needed. Tapping the button does a fast load of the current state. Then i can toggle to open the door. This works fine.
After that it try again to load the current state, but this takes ages and often times out. If I wait long enough (more than 7 minutes), I can close the door.
If I do the same with Google Home, i can open and close the door nearby instantly.
The Garage door is integrated in both cases via Homematic IP cloud.
Is there something I can do to speed the things up with Homeassistant, so that I can close the door faster? I assume that it times out somewhere. In which logfile can I check for errors or issues?
