Does anyone have any experiance sending voice commands to Assist or using tts using Node Red for an Atom Echo? I was able to catch the voice commands using the sentence node. But when I want to for example send a conformation of a command received in speech back to the Atom Echo i am a bit at a loss how. Using the tts service I cannot seem to find anything specific to send the text command too. I suspect I should not try and send it to the Atom Echo but to Assist? But how if that is the case?
I also use other smart speakers like Google Mini’s and there you can send a tts command to the speaker itself.
I don’t really have any node examples to share. All i currently have is a very basic setup with one sentence node to pickup the command and one call service node to try and send a response back.
